RJK350
posted on 2/5/10 at 08:51 PM |
Bike Instrument Issue!!!!!!!
Using Aprilia Tuono engine (2006), does anybody know if I have to use original instruments or could I use aftermarket?
I was told at Stoneleigh today, I would have to use original instuments for the engine. If not engine will not run. Is this true?
HELP!!!!!!
paulf
posted on 2/5/10 at 09:08 PM |
Some bikes use an imobiliser built into the clocks in conjunction with a chipped key.I had the chance of a GTR1400 engine but it had no keys and
therefore apparently needed clocks and ECU to run.
There may be a work around in your case or you could change to an after market ECU and clocks.
Paul
mark chandler
posted on 2/5/10 at 09:45 PM |
I think you will struggle to find an aftermarket ECU that can fire a 60 degree V twin, this could end up very costly.
Regards Mark
Rod Ends
posted on 2/5/10 at 10:11 PM |
Megasquirt has an odd-fire option for Harleys.
Richard Quinn
posted on 2/5/10 at 10:32 PM |
My motor is a bit older but, as per my U2U, I'm using an aftermarket dash. You won't get the fault codes etc if you use aftermarket clocks
but I haven't found it to be an issue.
Have you got a wiring diagram for the '06? I'll have a look and compare it to mine if you want. I think I've still got wiring
diagrams of what was left of the stripped out engine loom.
Out of interest, who told you it wouldn't work?
