RazMan
| posted on 7/5/10 at 10:37 AM |
What alternator is this?
My alternator has decided to self destruct and I need to order a replacement ..... the trouble is that my invoice doesn't give any details and
just states 'alternator'
Can anyone identify the make from the pic?
Raz
Staple balls
| posted on 7/5/10 at 10:39 AM |
I reckon Nippon Denso
flak monkey
| posted on 7/5/10 at 10:47 AM |
Looks like one of the small 'brise' type alternators as it can be mounted either side
http://www.brise.co.uk/alternators.html
Which are all denso type but there are literally 100's of denso alternators.
Sera
http://www.motosera.com
Werner Van Loock
| posted on 7/5/10 at 10:48 AM |
defo nippon denso, but you need the numbers to have the correct mounting etc.. as theres different models around
but as i can see there's no indictation on it anymore, seems to be removed for bling
can be found in daihatsu's, hyundai's, toyota's etc...
http://www.clubstylus.be
theconrodkid
| posted on 7/5/10 at 11:18 AM |
got my one from flea bay,came off a kubuto digger of some sort,brand spanking for £40 or so
who cares who wins
pass the pork pies
| posted on 7/5/10 at 11:40 AM |
as said Denso you can find manuals for it on the net
Actually looking at the plugs and bracket positions suspect it has its origins in the MG-Rover liquidation sale as it looks the same models as used on
some Rovers ---- if so I suspect it needs ECU control.
| posted on 7/5/10 at 11:48 AM |
Just had at my tintop look looks identical to the versions used 1.8 Rover K series.
| posted on 7/5/10 at 11:52 AM |
You say 'self destruct'.. what exactly happened? No chance of getting it fixed?
Too much throw away these days....
RazMan
| posted on 7/5/10 at 02:07 PM |
Thanks for the input guys, I'll have a word with my local spares distributor and see what he's got in the K-Series flavours.
By 'self destruct' I mean that the bearings are shot due to being run with a tight belt - it sounds like a bag of spanners being shaken up
(originally I thought the noise was my cam followers falling apart ). I suppose I could dismantle the thing and see if I can replace the bearings
but tbh they're not exactly expensive to buy as a complete unit.
| posted on 7/5/10 at 07:21 PM |
what £££ you talking aobut?
ebay for £ 85
has wiring diagram but different plug to yours so check for comaptability.
they are around that sort of price although I have seen them for much more .... and less too.
RazMan
| posted on 8/5/10 at 02:42 PM |
How about £25?
It turns out to be identical to this one but not sure of the current rating - it comes from a Toyota fork lift truck of all things!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160422729260&fromMakeTrack=true#ht_500wt_1182
I just whipped it off the car and discovered that the small bearing is totally shot and there seems to be another rattling noise coming from a loose
spacer (or something like that) inside the casing
If this eBay one is anything like 50 Amps or so I think I'll give it a try - my local alternator specialist just quoted me £60 to replace the
bearings or £120 for a new alternator!
[Edited on 8-5-10 by RazMan]
Raz
| posted on 8/5/10 at 06:39 PM |
£ 25 good find - even has same connector.
quick sums. 50 A is 600 W
head lamps 110 W, rear 50 W, indicator 20 W brake lamps 50 W ecu/engine 200 W
so you still have some W spare.
if you have lots of electric gizmos fitted then you'd need a bigger one and thye will be physicaly bigger.
so since yours is same size as the one in the link, you'll be fine
RazMan
| posted on 8/5/10 at 07:24 PM |
Pretty much what I was thinking. Actually my car is almost totally LED powered and the only conventional bulbs are the main beams (dips are HID) so I
reckon even with the lights, heater and even the stereo at full blast I should still be ok.
I've ordered one anyway
Raz
