Author: Subject: FS: front anti roll bar for inboard suspension
MK9R
posted on 8/5/10 at 06:44 AM Reply With Quote
As new, unused, Rob Farley designed 16mm diam front anti roll bar, only bought a couple of weeks ago off here, I was sure it would my fit my race chassis fury no problem, but I have modified my chassis and 2 large (and important) gussets are in the way and I do not want to modify them. I need to get a more conventional ARB that runs off the outboard lower wishbones.
New cost is approx £180 if you can get hold of one, I paid £148 for it inc postage, so looking just to try and recoupe as much as that as possible.
This will certainly fit a standard Fury, Stylus and other JP cars that have in board front suspension.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
posted on 9/5/10 at 05:55 AM Reply With Quote
bump
Cheers Austen
RGB car number 9
www.trackace.co.uk
antonio
posted on 10/5/10 at 06:52 AM Reply With Quote
hi
would be interested, depending on size.
can you pm'ed picture and total lenght?
cheers
MK9R
posted on 10/5/10 at 07:08 AM Reply With Quote
I'll get a picture sprted. There was one on here, but can't find it now!!!
Its approx 350mm long (slightly wider than the distance between the 2 upper wishbone to dampers pivots) and fits inboard between the wishbones on the lower chassis diagonal rails behind the lower damper mounts.
Cheers Austen
RGB car number 9
www.trackace.co.uk
antonio
posted on 10/5/10 at 08:39 AM Reply With Quote
can't find the picture too.drop me a line when you have one please
antonio
welderman
posted on 10/5/10 at 01:09 PM Reply With Quote
are they made from hardened steel ?
Thank's, Joe
I don't stalk people
MK9R
posted on 10/5/10 at 01:11 PM Reply With Quote
No idea, its the ones that Rob Farley sells. Thats all i know, sorry
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 24/5/10 at 07:37 AM Reply With Quote
Pictures added
pictures as requested
Cheers Austen
RGB car number 9
www.trackace.co.uk
