IainL
| posted on 19/5/10 at 06:48 PM |
Sierra Ignition Key
Just brought a steering column off Ebay, but there was no key for the the ignition switch!
Therefore is there a way to find out what key would fit or am I going to need to remove the old ignition switch and find a replacement complete with
key?
Davegtst
| posted on 19/5/10 at 06:52 PM |
If you can get the barrel out in one piece you can get a key cut to fit. Probably quicker to drill it out and get a replacement barrel and key.
big-vee-twin
| posted on 19/5/10 at 06:56 PM |
You can get a new barrel and key cheaper off ebay I got mine from a seller called all parts ford
link
[Edited on 19/5/10 by big-vee-twin]
http://www.triangleltd.com
eznfrank
| posted on 19/5/10 at 08:01 PM |
I have one I'm not using. I can try take it out if you want - £10?
