RobBrown
posted on 22/8/02 at 11:23 AM |
Headlamp Wiring
I have got the stage of wiring all the lights. Pretty much there, all Flashers working fine, Front and rear side light OK as well
I have spent 3 nights trying to wire up the Headlights Dim and dip. I am using the Haynes Manual as a guide (as it worked with the above), but the 4
relays it uses has completely baffled me.
I even tried to do away with the relays and wire them directly with a normal switch, but I am finding that only one of the lights work at any one time
this way.
Do any of you have a diagram I can follow? or any tips(Apart from burn the Haynes manual!!).
I'd ideally like to use the stalks from my donor (a Sierra).
Rob
theconrodkid
posted on 22/8/02 at 05:00 PM |
You dont need dim dip,if you are using the ford loom they are fused ,one each side,looks like disconect the wiring and start again using a circuit
tester instead of a wiring diagram,what relays are you using,4 or 5 pin?
stephen_gusterson
posted on 22/8/02 at 05:53 PM |
wiring up the main lights is easy - i can confirm you dont need dim dips. You will need relays for the lamps tho.
I have another hand drawing of how I did mine with ford bits. let me know if you want me to post it.
atb
steve
RobBrown
posted on 22/8/02 at 09:27 PM |
The 4 relays I have been using are a mixture of 4 & 5 pins. Each of the relays are labelled as follows:
Dim/Dip Relay II (5 pin)
Dim/Dip Relay B (4 pin)
Dip Beam Relay F (4 pin)
High Beam Relay X (5 pin).
I am not using the loom from the Sierra, as there was so much of it I didn't need, that I got over exited and removed a lot more than I should have
done. So I am virtually starting from scratch.
Since Dim/Dips are not required I'll do away with all these relays and get the circuit tester out, and i'll try and work it out that way.
Do I still need to fuse the left and right independently, and the main beam independently from the full beam (i.e. 4 fuses for the headlamps)
RobBrown
posted on 22/8/02 at 09:28 PM |
theconrodkid
posted on 22/8/02 at 10:40 PM |
Best to keep it simple,i got 1 fuse for sides and 1 for main 1 for dip
stephen_gusterson
posted on 22/8/02 at 11:45 PM |
simple is good, and i used 1 fuse per beam, and one for sides too.
however, the right way is to use one per beam. that stops a short taking out all the lights on a dark road. sure youu could grab the dip switch and
change over, but its not so good.
There is nothing 'trick' about the headlamp relay, however some have diodes and crap in em which isnt good. Best way is to take some from a car fuse
box thats telling you what they are! On a ford granada/sierra, the correct relay is black. The coil connects to pins 85 and 86 and the switched
contacts are 87 and 30.
4 pins only
atb
steve
RobBrown
posted on 23/8/02 at 12:10 PM |
Thanks Chaps,
I'll give that a go this weekend
Rob
