neilp1
| posted on 27/5/10 at 03:31 PM |
Main beam problem
Hi all, I have changed all the switches to toggle switches using a large off/on/on one for the side lights/dipped headlights and a small off/on for
the main beam.
The problem I'm having seems to intermittent. the main beam works fine on it's own (switching the switch to on), but sometimes when I
switch the dipped headlights on the main beam is on even though the main beam switch is off. Then when I switch the engine off and restart it, it is
fine. Side lights are fine!
Any ideas??
RichieHall
| posted on 27/5/10 at 03:47 PM |
Sounds like you may have an earthing problem?
Have a good scout round the engine bay and make sure you don't have a loose earth strap or have one thats become corroded.
Rust is lighter than Carbon Fibre!
russbost
| posted on 27/5/10 at 09:09 PM |
or relay remaining latched in?
