Author: Subject: Anyone use a MAF sensor with an aftermarket ECU?
turbodisplay
posted on 6/6/10 at 03:49 PM Reply With Quote
As above, thinking of fitting a new processor (32 bit 80 mhz) to my ecu and using maf sensors, instead of a map sensor.
Reason being is that sequential turbo requires diferent maps as the VE will change depending on which turbos are working.
Anyone have any pointers, problems thay found with MAF?
Darren
MakeEverything
posted on 6/6/10 at 04:18 PM Reply With Quote
Its supposed to be less accurate..... apparently. Megamanual says that MAP is more precise and offers a better VE table, but ive yet to try either!!
Kindest Regards,
Richard.
turbodisplay
posted on 6/6/10 at 04:31 PM Reply With Quote
See my best guess is that it is less accurate as megasquirt is quite a basic system. What a car manufature does is calculate how much air is going into the engine per stroke (mass/rpm = mass per stroke) whereas megasquirt uses a voltage to feed into the table so has lesss dynamic range.
Looking at bosch data the accuracy is 3% which i recon is better than map if you consider how the manifold pressure varies (valve pulses etc).
One plus point is that mapping should be easier as you know the mass flowing in so you kow how much fuel is needed for a given afr. Rather than guessing VE.
Darren
posted on 6/6/10 at 05:26 PM Reply With Quote
Dynamic range can be a problem with turbo applications - I know the MAF sensor on my tin top isn't capable of measuring flow at WOT and high RPM. AFAIK the ECU uses a MAP sensor in this case.
tomgregory2000
posted on 6/6/10 at 05:46 PM Reply With Quote
My SR20DET runs MAF only and an Apexi power fc ecu
