Author: Subject: Interesting gear indicator
clairetoo
posted on 6/6/10 at 05:00 PM Reply With Quote
Just found this - LINKY - might be of use to some here ?
And I was wondering if the forward/backward movement of a car type gear lever would work ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 6/6/10 at 05:23 PM Reply With Quote
I can see that kind of design getting out of sync with the actual gear selected at the first missed shift, or when getting into neutral etc.
liam.mccaffrey
posted on 6/6/10 at 06:46 PM Reply With Quote
I thought that, but you could sanity check it with an rpm/wheel speed comparison.
Build Blog
Build Photo Album
posted on 6/6/10 at 09:16 PM Reply With Quote
I invented an almost identical PIC based one which is still on my website....
Works fine once you have the microswitches set up correctly....
