scoobyis2cool
| posted on 22/5/04 at 05:03 PM |
Started motor wiring
Can anyone tell me what each of these terminals are for?
I've got 3 wires to connect to the starter - supply from battery, wire to alternator, and wire to ignition. Which terminal do i connnct these to?
Presumably the supply from battery and wire to alternator go to the same terminal?
By the way the starter is off a 1600 pinto
Pete
[Edited on 22/5/04 by scoobyis2cool]
theconrodkid
| posted on 22/5/04 at 05:13 PM |
big cable from battery and big one from alternater go to the same terminal,small one is to start switch/button
who cares who wins
pass the pork pies
scoobyis2cool
| posted on 22/5/04 at 05:15 PM |
That's what i thought it probably would be, but for some reason the connectors that are supposed to go on the same terminal have different sized
holes - the battery cable fits over the large terminal but the cable to the alternator doesnt, i guess they must have just fitted the wrong end piece
and i'll have to drill it out a bit
Pete
| posted on 22/5/04 at 05:17 PM |
You can take the one from the alternator back to the battery if it's easier.
scoobyis2cool
| posted on 22/5/04 at 05:27 PM |
I think with the way my loom is set out it will be easier to just drill the connector a bit bigger, this won't affect the current through it and
cause big bangs will it?!
Pete
| posted on 22/5/04 at 05:56 PM |
No it's just the same as connecting the two wires together in a different place. It'll still put power back to battery.
