Alistair
posted on 23/5/04 at 10:12 AM |
Indicators interfere with other lights
When the hazards or indicators are in operation they cause the front and rear lights to dim as well as the lights on the dash instruments. This was a
reason for failing my recent SVA. The amount they dim by is tiny, only visible if you look really closely. The effect is present when the engine is
both running and switched off.
Any suggestions please as hours of picking through the loom, checking earths and replacing connectors has proved fruitless.
posted on 23/5/04 at 10:23 AM |
id use thicker wires. do the indicators share feeds or earths with these other lights?
mangogrooveworkshop
posted on 23/5/04 at 10:32 AM |
As a man formally of the smoke pipe trade (Sparky) It would appear that the feed from your battery to the fuse box may be undersized. uprate this
cable and your problem should go away. High resistance at the battery terminal crimp can do it to. Try another battery even new ones come in
faulty.
at college they told use about the skin effect and electrons....liars smoke pipes i say....reason when smoke comes out thing stops working.....must
have run on smoke........LOL
theconrodkid
posted on 23/5/04 at 01:11 PM |
also check the earths on the light units
who cares who wins
pass the pork pies
Danozeman
posted on 24/5/04 at 07:33 PM |
Check the earths first. Easiest to do..
Dan
posted on 24/5/04 at 08:22 PM |
Earths would be my first choice too - my 2p's worth!
That and the battery condition...
[Edited on 24-5-04 by Hellfire]
Alistair
posted on 27/5/04 at 11:43 AM |
Sorted it.
It was the battery that was the problem.
Changed the battery and everything seems to be fine.
Thanks for your help.
