Mark Allanson
| posted on 25/6/10 at 12:13 PM |
Help - any car thieves here? :)
I took my car to work today and the ignition switch has promptly fallen apart.
I need to hotwire it to get home, which wire to what to get it going? I am on lunch until 1:30pm and finish at 5:00pm so won't be able to add
anything further.
The image is blured due to the cheap works camera (also no resizing software here), but the colours are red, black/blue, black/yellow and yellow
Mark
PS new one from Ford arrives Monday
big_wasa
| posted on 25/6/10 at 12:17 PM |
pic
| posted on 25/6/10 at 12:18 PM |
Got a multimeter? +12v. Ground. and two with nothing?
1 nothing is the ign, the other nothing is the starter..
Or is the switch at the back of the barrel intact?
big_wasa
| posted on 25/6/10 at 12:19 PM |
Red to Black and yellow to run and red to black and blue to start.
Mark Allanson
| posted on 25/6/10 at 12:41 PM |
Just finished lunch and a quick fiddle - the switch is knackered and looks to have been for some time!
I think I will also have to connect red to yellow to prime up the fuel pump?
Better image attached
big_wasa
| posted on 25/6/10 at 01:15 PM |
I would doubt that. Yellow is for the radio and a few other bits and bobs but not the fuel pump unless you added it to there ?
jossey
| posted on 25/6/10 at 01:20 PM |
are you sorted now?
blakep82
| posted on 25/6/10 at 01:51 PM |
isn't it connect red to black/yellow permanantly to activate ignition, fuel pump etc, then touch red to black/blue to fire up the starter?
the to stop the engine disconnect red to black/yellow?
________________________
| posted on 25/6/10 at 01:54 PM |
Twist together the B+Y, Y and R wires, Flick the B+R wire onto that bundle. Simples.
Mark Allanson
| posted on 25/6/10 at 02:02 PM |
quote: Originally posted by jossey
are you sorted now?
I should be, 5pm will tell though
thanks everyone
Mark
mookaloid
| posted on 25/6/10 at 02:32 PM |
Sounds like the voice of an experienced car thief
mangogrooveworkshop
| posted on 25/6/10 at 02:54 PM |
I am an ex burglar.......
Burglar bar specialist used to work for expanda...... I used have to break in to installations.....when clients locked themselves in or out.
Such is the wealth of experiance on locostbuilders.....
jossey
| posted on 25/6/10 at 02:57 PM |
black boxing your own car what has the world come to.
if you can get some tape on the 3 wires you need perminent to stop them coming apart when you hit a bump or anything. the wire is so thick they can
pop apart sometimes and leave you slowing down on motorway.
dave j
dave
| posted on 25/6/10 at 05:18 PM |
Please remember the steering lock, I have a Barrel if you are interested in purchasing.
Staple balls
| posted on 25/6/10 at 05:38 PM |
IIRC the barrel and switch are separate, if the switch is shaggered, the steering lock is probably okay, as it's mechanically done from the
barrel/key, rather than the leccy bits.
Mark Allanson
| posted on 25/6/10 at 05:42 PM |
Hot wired as per advice and got home safely- The steering lock and barrel are unaffected, just the switch.
Again thanks to everyone, typical of the way this site works. thanks to Chris for hosting it and Fozzie for keeping us all in check!
RoadkillUK
| posted on 25/6/10 at 07:31 PM |
Our car has had a dodgy switch, just got it fixed, but for about 3 weeks, we were hotwiring it in the same way. There is a muliticonnector not far
back from the ignition switch, just push wires into that.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
bimbleuk
| posted on 26/6/10 at 05:38 AM |
Not too long ago my audi A4 wouldn't start on the key and left me stranded at work. Quick search on the net and I hot wired the starter. Still
needed the key in the ignition turned to ON to start.
When I got home I mounted a flick switch on the column from my kit car bits. Great theft device as no one has notice the switch when they try to start
it. So I didn't bother fixing the barrel.
