dave107
| posted on 26/6/10 at 03:25 PM |
Radiator Fan Thermal Switch
Doing some wiring today and got to the Radiator fan thermal switch, i have two wires one earth and one black and green but don't know which
terminals on the switch i have to connect to switch has no markings, does it matter on these thermal switches.
Help much appreciated.
Thurbs
| posted on 26/6/10 at 03:38 PM |
switch
Doesn't matter it's just a normally open switch and just closes when temp is reached.
matt_gsxr
| posted on 26/6/10 at 03:39 PM |
it shouldn't matter as it is just a switch.
You could check that neither of the terminals are earthed to the body of the switch, but I don't think they normally are.
dave107
| posted on 26/6/10 at 04:11 PM |
Thanks guys for quick replies, now i can move onto next part of wiring.
| posted on 26/6/10 at 08:05 PM |
wrong - it does matter.
depending on the model of switch, it can have one or two tabs.
the one terminal is simple - the tab and the body are the contacts for the switch.
with 2 tabs the two tabs may be the contact or they can be two separate switches (operate at diffrerent temperatures) with the body as the second
contact of each.
also most switches are NO - normally olpen - the contact closes when temp is reaced or less common, can be NC - normally cllosed and the contact open
my advice is to find out what each contact does on t he switch; easy to do it you have a container of water that you can ehat to boiling and a
multimeter to measure resistance between the both tabs and tabs and stich body.
chances are they are both contacts for the switch, NO, but who can really say?
dave107
| posted on 27/6/10 at 10:27 PM |
02GF74 i hope iv'e done this correct here are a couple of images of the switch can you tell from this if the wires matter which way round they
go.
[img]http://i562.photobucket.com/albums/ss67/dave107photo/thermalswitch2.jpg?
t=1277677420[/img
http://i562.photobucket.com/albums/ss67/dave107photo/thermalswitch1.jpg?t=1277677420
dave107
| posted on 27/6/10 at 10:31 PM |
Above attachments have not worked will try again tomorrow,
| posted on 28/6/10 at 08:25 AM |
oh, I wish I were that good to be able to tell you what switch you hve from the photo.
please take a peek here: http://www.intermotor.co.uk/
intermotor, selet part, radiator fan switch.
dave107
| posted on 28/6/10 at 12:30 PM |
Thank for the link 02GF74 i will have a look tonight and see if i can find a part number.
Dave
| posted on 1/7/10 at 06:50 AM |
if you struggle, then test it as per previous post - that way you will know the witch is working. (if you don't have multimer or
bulb/wire/battery, thermometer, stove and pan of water, then pop it in the post and I can get the spec, for you).
dave107
| posted on 1/7/10 at 09:24 AM |
02GF74 Thankyou very kind gesture always rely on help on this forum, have brough the switch and my multimeter into work today to do test let you know
how i get on.
Thanks again
Dave.
