Author: Subject: Tacho Wiring MS & Digidash
Bumble
posted on 12/7/10 at 09:21 AM Reply With Quote
Hi all,
I now have pretty much everthing working on the car but can't get the ETB Digidash Lite to read RPM from the MS ECU. It's an Extra EFI MS1 V3.0 with Tacho Output.
Any ideas??
Matt
eddie99
posted on 12/7/10 at 09:22 AM Reply With Quote
Don't mean to hijack thread but i also have this problem with acewell and omex ecu.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
scudderfish
posted on 12/7/10 at 11:46 AM Reply With Quote
Are you running EDIS?
Bumble
posted on 12/7/10 at 11:59 AM Reply With Quote
no not running EDIS....running wasted spark controlled from MS.
Thanks,
Matt
posted on 12/7/10 at 12:05 PM Reply With Quote
Same problem with my Acewell.. sorry to say its connected to the EDIS and works now.
Bumble
posted on 12/7/10 at 12:11 PM Reply With Quote
Someone out there must be using MS on wasted spark with an ETB Digidash Lite and getting Tacho to work......Help please!!
scudderfish
posted on 12/7/10 at 12:31 PM Reply With Quote
Is the RTB tach input designed for ECU or coil?
Snuggs
posted on 12/7/10 at 01:04 PM Reply With Quote
I can make you one of these if you want.
4th item down
£5 posted
[Edited on 12/7/10 by Snuggs]
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
Bumble
posted on 12/7/10 at 01:58 PM Reply With Quote
Snuggs.......If it works then I'll take one. I have a single Tacho output from the MS and a single input to the Digidash. So in my case how does it connect up and do you know if it works with the ETB Digidash lite??
Matt
4th item down
£5 posted
Snuggs
posted on 12/7/10 at 02:34 PM Reply With Quote
Matt
4th item down
£5 posted
It works by taking a feed from the -ve of each coil. eg A standard 4cyl coil pack has 2 -ve connections.
Then another wire from the unit feeds to the tacho input.
The ones I make will do 4, 6 and 8 cyl setups. Just cut off and tape up the spare wires.
I use one of these on my V8 that has Megasquirt/EDIS8 and 2 Ford coil packs.
Snuggs
posted on 13/7/10 at 09:01 PM Reply With Quote
Matt, You have U2U
Clive
