Michael
posted on 14/7/10 at 08:16 PM |
LED Side Repeaters
Will i need a special indicator relay to run the two LED repeater lights sold on the bay.
http://cgi.ebay.co.uk/robin-hood-locost-westfield-IVA-INDICATERS-1-pair-LED-/260631220012?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&ha
sh=item3caed4cf2c
eznfrank
posted on 14/7/10 at 08:19 PM |
I bought some of the same and they don't work with my current relay, think they need a diode or resisitor or something. I told kitpartsdirect
but they didn't seem to understand
Michael
posted on 14/7/10 at 08:20 PM |
Sorry for your troubles but i am glad i asked now.
Thanks will go for the ones from the Land Rover Defender then.
big_wasa
posted on 14/7/10 at 08:28 PM |
Ive also got a pair of them and they work fine with the standard hot wire relay...
Stott
posted on 14/7/10 at 08:49 PM |
They flash too fast with my std sierra relay, I'm gonna get the ebay one for £14 odd which does a range of wattages so you can mix n match all
your lamps and it won't blow up
big_wasa
posted on 14/7/10 at 08:56 PM |
The rest of mine are standard bulbs so there is very little wattage differance.
Stott
posted on 14/7/10 at 09:20 PM |
yeah me too, 21w on f + R, I guess if I timed it they would be inside the iva limits it just looks a little odd, to me anyway!
Least of my problems though, the completely unfinished car being my main problem!
[Edited on 14/7/10 by Stott]
RazMan
posted on 14/7/10 at 10:39 PM |
LED repeaters won't make any difference to the flashing rate because they are only replacing a very small wattage bulb. Whatever you do, do not
go putting resistors in parallel with anything - they are a fire risk!
If you want to run LED indicators just get an electronic flasher unit to do the job properly - you can usually run up to one conventional bulb with
them too.
Raz
Stott
posted on 15/7/10 at 08:29 AM |
This is what I'm getting: LINK
cd.thomson
posted on 15/7/10 at 09:16 AM |
I have these lights and they work fine with my original sierra relay!
Craig
