Author: Subject: help with mondeo loom strip for zetec conversion
doddy
posted on 20/7/10 at 07:25 PM Reply With Quote
hi my mate is converting his dutton to zetec engine, he has a 1999 mondeo he wants to use the loom from the mondeo but strip unneeded parts deos any one have instutions or pointers on how to remove the alarm or help run the car because at the monent it seems to be not wanting to start or turn over
cheers doddy
[Edited on 20/7/10 by doddy]
big_wasa
posted on 20/7/10 at 07:44 PM Reply With Quote
I can do upto 97 no problems. Ive got a 99 comming for me to decode
How far has he got ?
does he have the key for the ecu ?
has he got the antena from around the ignition.
The antena has four wires one is perm 12v and another earth the other two are tx / rx and go to the ecu.
On a 99 they will all be black has he got them wired correct ?
the ford Tis states that for around that year security went up with the alarm being codded to the ecu aswell as the key.
Ive had a one go but couldnt get it to go but that was just with the ecu.
Like I say ive got a full car to play with in a few weeks so maybe of more help then.
An aswer to your question is there are no specific instructions as pin numbers and wiring colours change between model year and spec.
Mev have done instructions for a focus of a specific year.
Find your self a copy of Autodata. the Tis cd you can get on ebay is bugger all use.
[Edited on 20/7/10 by big_wasa]
doddy
posted on 20/7/10 at 08:01 PM Reply With Quote
hi he has the key and the decoder as hes still has the whole mondeo the he drice to hes house so it should all work
as you said it has a extra alarm bit we have pluged it all in in the dutton but when you turn it on you get all dash lights like nomal the alarm light flashes fast and thats it
does he have to have the central locking wired up or anything like that
im not saw how many wires are on the decoded i will try and find out
cheers doddy
big_wasa
posted on 20/7/10 at 08:11 PM Reply With Quote
The alarm status light flashes to say its not detecting a valid code from a key.
Antena will have four wires and one must be perm live and not switched. Earlier ecu's did not need the alarm pluged in.
You also need the perm 12v to the ecu.
I take it he has laid the whole loom in there with fuse box ?
doddy
posted on 20/7/10 at 08:24 PM Reply With Quote
hi yes the full loom is in the car and its the same key hes started it with before only this missing are things like the door plugs and air con plugs
i just rang him Antena had 4 wires will need to check if there is a live to it
