Author: Subject: iva advice. handbrake light
RMarine
posted on 25/7/10 at 01:12 PM Reply With Quote
do i need to have a handbrake warning light to pass the iva?
bonzoronnie
posted on 25/7/10 at 01:27 PM Reply With Quote
Yes, I believe you do.
I believe you also need a low fluid level warning light too.
On most production cars, the same light is used for both
FrankP
posted on 25/7/10 at 01:35 PM Reply With Quote
I don't have one and passed fine
You do need a low brake fluid warning light that can be tested with the ignition off.
Frank
RMarine
posted on 25/7/10 at 02:10 PM Reply With Quote
not sure, i'll check later today and getg back to you
ReMan
posted on 25/7/10 at 02:31 PM Reply With Quote
Originally posted by FrankP
Frank
With the ignition off? Is that a fact?
interestedparty
posted on 25/7/10 at 02:36 PM Reply With Quote
I think thats wrong, never come across a car with a brake fluid warning that lights or can be tested with the ignition off.
RMarine
yep it works with the inj off or on
[Edited on 25/7/10 by RMarine]
iank
posted on 25/7/10 at 03:04 PM Reply With Quote
No handbrake warning light required, though the brake fluid bulb test is usually miss-interpreted as that function as it's where most manufacturers put the test switch.
Anonymous
blakep82
posted on 25/7/10 at 04:42 PM Reply With Quote
^ plus 1
________________________
interestedparty
posted on 25/7/10 at 04:47 PM Reply With Quote
what does brake fluid level test or handbrake?
snapper
posted on 25/7/10 at 06:23 PM Reply With Quote
You do not need a handbrake warning light..
You do need a brake fluid level warning light, this should have a test switch as well as a warning light.
Most manufacturers use a switch on the hand brake so when you turn the ignition on it glows, when you drop the hand brake it goes off..... Unless the fluid level is low then it stays on.
No it does not illuminate when the ignition is off or it would glow all the time.
[Edited on 25/7/10 by snapper]
I eat to survive
I drink to forget
