Tommy P
posted on 28/7/10 at 03:42 PM |
Recommendations for Geometry set up
I want to have the suspension geometry checked and set up and corner weighted on My Fury.
I'd like to have it set up quite precise for fast road and track.
Any recommendations as to where to go for this near the Wigan area.
prawnabie
posted on 28/7/10 at 04:10 PM |
I know its not in wigan, but I might as well start the first of many recomendations for procomp in bham- top lads.
YQUSTA
posted on 28/7/10 at 06:09 PM |
I can second ProComp.
They are great guys and do a great job, completly transformed my car. The price is very good for the work put in and if like me you are a novice you
will learn alot too.
Worth the trip down in my opinion allthough I believe Matt has broken his ankles so you may have to wait a little while.
"If in doubt flat out"
Colin McRae
PeteS2k
posted on 28/7/10 at 06:13 PM |
John Clarkson Autos, Chorley
http://www.johnclarksonautos.com
franky
posted on 28/7/10 at 06:52 PM |
Ive previously used northampton motor sport, great guys really know their stuff across all types of sports cars. Their workshop is like an aladins
cave of cars.
Steve Hignett
posted on 28/7/10 at 07:03 PM |
I would also suggest that the trip down the M6 to birmingham, Procomp would be worth the trip...
That is of course if he's got up off his lazy arse by now...
Tommy P
posted on 29/7/10 at 03:58 PM |
Will consider the trip to procomp.
Clarksons is just round the corner from me and welderman suggested them too.
What does it cost anyway.
Ta
mitch2b
posted on 29/7/10 at 04:54 PM |
pheonix motorsports, Nr Accrington,
01254 384071,not sure how much a full goe is but would think £80 upwards,
did my Rhood one sat morn and i know of a friend who took his mnr racer there to be done, and transformed its handling,
they are a lotus Elise specialist, but i have seen anything from lambos and bentleys to my old disco in there,
hth
Mitch
procomp
posted on 30/7/10 at 09:29 PM |
Hi
"That is of course if he's got up off his lazy arse by now... " yea yea. Hoping to be out of the chair and on crutches next week
after a trip to the funny farm known as the Hospital.
Our prices are £200 for a full and i mean full setup Inc all 4 dampers dyno tested and set and the springs checked for poundage.
Cheers Matt
bonesetter
posted on 31/7/10 at 09:23 PM |
Sounds good - I'll be in touch this week for you to set-up my Mac#1 I've just bought.
Needs it badly as is quite nervy
Should the steering self centre?
As it is once the turn has been initiated the steering wants to tighten up the turn even more into an ever decreasing circle... ![](/images//smilies/shocked.gif)
procomp
posted on 1/8/10 at 03:46 PM |
Hi
They never self center that good due to the inbuilt geometry lacking Castor usualy down on around 2-4 where as it really needs 5 Minimum. But it
should make at least some attempt to straighten even with those sort of figures. If it tries to tighten the turn then there's something set
wrong . Possibly the top wishbones on the wrong way around or some other Geo setting way out. But check the top wishbones have the shorter leg to the
rear. When looking from above at the top and bottom joints the top joint should be around 10-20mm backward of the lower one. 20mm gives around 5
degrees of castor.
Cheers Matt
bonesetter
posted on 1/8/10 at 08:38 PM |
The arms and top/bottom joints do look as you say they should
I'll give you a ring tomorrow and get it booked in
Nigel
