Author: Subject: Headlamps...
posted on 5/9/10 at 12:24 PM Reply With Quote
Headlamps...
On an 'all-in-one' headlamp (side, dip, main), what does the fifth wire do?
I get the side, dip, main and earth wires, but that leaves one spare... does the 'pass' (flash) function have it's own circuit?
It's Evolution Baby!
RichardK
posted on 5/9/10 at 01:49 PM Reply With Quote
side & earth
Dip/Main & earth
Maybe??
Gallery updated 11/01/2011
posted on 5/9/10 at 01:55 PM Reply With Quote
Cheers Richard, so you're suggesting that the side bulb may not share it's earth with the dip / main bulb and has it's own?
Methinks I will have to have a lookie inside the bowl!
alexg1965
posted on 5/9/10 at 01:59 PM Reply With Quote
It might be so that you can wire it up like the Sierra (have a look in the Haynes manual if you have one) as the RH headlamp has 5 wires, although the LH one has 4. From memory on my last car, it was all to do with the dip/main beam switch.
russbost
posted on 5/9/10 at 05:01 PM Reply With Quote
dominatore definitely have 2 separate sidelamp wires as the sidelamp holder isn't earthed to the body of the lamp
posted on 5/9/10 at 05:08 PM Reply With Quote
Cheers muchly!
RichardK
posted on 5/9/10 at 09:13 PM Reply With Quote
You are most welcome my friend.
R
