The Baron
posted on 11/9/10 at 04:02 PM |
Zetec & Ignition from a old Escort
I am replacing my pinto engine with a Zetec. I am using a MK2000 Carb which is on a custom manifold adaptor plate.
I was planning to use an old ignition module from a Mk4/5 escort (the last once to use a carb'ed CVH engine)
I have a 'esc' (no a edis) module but........ does any one have a wiring diagrame to connect it to a zetec? and/or does any one how to
check if the module pack is any good?
Cheers in advance
B
big_wasa
posted on 11/9/10 at 04:24 PM |
Is it the black esc with the red cover ?
The Baron
posted on 11/9/10 at 04:29 PM |
Yes, whith what looks like a little plastic tube comming out of it.
big_wasa
posted on 11/9/10 at 04:32 PM |
If its the one with one temp sesor then this is the wirring digram.
If it has two then you can still use it as a guide from the above.
Later ecu's had an extra air temp sensor aswell as the coolant temp sensor.
Hope this helps.......
The Baron
posted on 11/9/10 at 04:34 PM |
Ta very much, i'll have a go tomorrow.
B
big_wasa
posted on 11/9/10 at 04:51 PM |
If you have the loom there is only four or five wires.
One is oil presure light that is in the loom. Some models have a tacho which is just a signal from one of the coils . Then there is the switched power
and earth for the whole thing.
there is a live that went to a valve in the old carb, I think this was to stop it running on.
MikeR
posted on 11/9/10 at 05:16 PM |
Daft question - apart from the fact you can program the megajolt to your engine, does this just do the same thing?
The Baron
posted on 11/9/10 at 07:17 PM |
one last question, is the coolant temp sensor the one with the round plug, or the one with the square plug?
B
big_wasa
posted on 11/9/10 at 07:32 PM |
They are both a round two pin plug.
Have you got a pic of the loom ?
Yes does the same thing as a mgajolt but no trial and error and no programing just plug and play.
Down side is the advance cure is not the best for a zetec.
When I could find them I was paying £10 for all the bits to make it run bar the carb and manifold.
Cheap and cheerfull you pay's your money's ect
The Baron
posted on 11/9/10 at 07:49 PM |
Hello again,
being really impulsive, i have just purchased a EDIS4 module as well (no ebay will power im afraid ) is the wiring diagram the same?
I know its not ideal, but i am on a really tight budget, so far the whole conversion has cost me about £60 including the engine. Only a new exhaust
manifold to go....
B
big_wasa
posted on 11/9/10 at 08:30 PM |
No edis 4 is differant. Look on autolabs website for that.
For what you want the esc is better, the edis 4 has no controller and will just run at 10deg btdc and will run like a bag of spnners compared to the
esc.
Like I said esc is fine on a budget. You can always run it for now and make a profit when you sell it to some one who doe banger racing.
RegW
posted on 16/6/13 at 06:11 PM |
ZETEC + ESC: wiring diagram + power?
Hi - Big-Wasa mentioned a diagram to fit a red ESC with a ZETEC - can I see it as well?
Also, how much bhp can I expect with R1 carbs?
Is megajolt so much better - or do you also end up with a close to 10deg advance?
Thanks!
