Author: Subject: Is my alternator knackered, and has it done in my battery?
scudderfish
posted on 26/9/10 at 09:08 AM Reply With Quote
My battery doesn't seem to hold charge, and it has previously vented. I hooked up my voltmeter, and it was showing 12.5v (ish). I started the engine, and when the alternator was running the voltage was getting as high as over 17v and consistently over 16.5v. Is this bad news? I expected the voltage to be more around 14.5v when charging.
MakeEverything
posted on 26/9/10 at 09:10 AM Reply With Quote
Sounds like its cooked the battery, which has vented.
Charging should be around 14.4 - 15V. 17V consistently would probably have killed the battery.
Sorry bud.
ETA: Thats what you get for having a dig at me all week!!
[Edited on 26-9-10 by MakeEverything]
Kindest Regards,
Richard.
snapper
posted on 26/9/10 at 09:14 AM Reply With Quote
Alternator unwell, charging voltage 13.9 14.5 ish
I eat to survive
I drink to forget
fazerruss
posted on 26/9/10 at 11:11 AM Reply With Quote
sounds like your regulator is buggered
"if assholes could fly this place would be an airport"
RazMan
posted on 26/9/10 at 11:20 AM Reply With Quote
As above, it is likely to be your regulator on the blink. You can sometimes find a replacement at alternator repair companies - or simply replace the alternator.
Unfortunately it may have taken your battery with it, so its best to get it checked out at a battery specialist who can see if it has done any lasting damage.
[Edited on 26-9-10 by RazMan]
Raz
posted on 26/9/10 at 04:45 PM Reply With Quote
Starting with a battery with decent charge ie showing 12.5 or more volts accross the termminals with everything switched, measure the battery voltage cranking the engine (best done cold cold & ignition coil disconnected), if the voltage acrross the battery is less than 9 volts the battery is goosed.
[Edited on 26/9/10 by britishtrident]
scudderfish
posted on 26/9/10 at 05:10 PM Reply With Quote
Looking back at the megasquirt logs from my MOT yesterday, I stopped at a garage afterwards and it wasn't keen to start. Voltage dropped to 8.5v during cranking, so it is officially more goosed than Meg Ryan's character in Top Gun
