ditchlewis
| posted on 2/10/10 at 07:41 PM |
light switches
I seem to be missing some thing (common sense and thinking before i act). i'm using the viccki green loome.
Having fried the electrics (Lighting), i have replaced all the rear lights and fitted a rotary switch as i'm sure that the stalk switch was
fried (side light Part only).
previously i had no side lights and only dipped and main beam. i thought i understood the wiring diagramme but now i have side lights but no dipped or
main beam, but i can flash the lights.
I have put the side light cable from the stalks to the new switch. I have taken a +ve feed from the switch /stalk (i split the stalks switchd +ve) and
i have taken the wire from the from the dipped beam relay to the switch.
what am i doing wrong?
ditch
RichardK
| posted on 2/10/10 at 08:06 PM |
Have you had a look at the modified vicky diagram? May give you a pointer..
Linky
Rich
Gallery updated 11/01/2011
ditchlewis
| posted on 2/10/10 at 08:28 PM |
sorry about the kiddy style drawing, but it might help clarify what i have done
this is what i have done.
The switch stalks are sierra
ditch
