Author: Subject: Racing battery....
pekwah1
posted on 14/10/10 at 08:45 PM Reply With Quote
Racing battery....
Quick battery question, would this be any good for a sylva striker.
Currently has a crossflow which will turn into a zetec or similar at some point....
http://www.apexperformance.co.uk/catalog/product_info.php?cPath=&products_id=1394&PHPSESSID=b27c6f588a9ca380819d70f8a77ce10b
andy
norfolkluego
posted on 14/10/10 at 09:31 PM Reply With Quote
Don't know anything about that one but for that price you could get an Odyssey racing battery (and probably a Varley) and they are good, start my Zetec first time, every time.
pekwah1
posted on 14/10/10 at 09:32 PM Reply With Quote
i'll be paying £60, my mate has a brand new one he doesn't want
norfolkluego
posted on 14/10/10 at 11:03 PM Reply With Quote
Good buy at that price, just make sure it's big enough to crank your engine (i.e check the cranking amps you're looking for over 180, 200+ is better)
[Edited on 14/10/10 by norfolkluego]
pekwah1
posted on 14/10/10 at 11:04 PM Reply With Quote
well it was for a nissan 200sx with a 2.0 turbo, so thinking about it, don't know what i'm worried about! if it can start that, will do fine on my diddy ickle thing!
Davey D
posted on 15/10/10 at 06:34 AM Reply With Quote
you should be fine. the spec says:
31Amp/hr, 475CCA
when i had my 200sx i had a varley redtop powering it. that had 625CCA i believe. it actually made it crank over quicker than what the original battery did
bimbleuk
posted on 15/10/10 at 08:48 AM Reply With Quote
I always had 19 Amp/hr bike batteries on my Striker with a 4AGE so that should be fine.
matt_gsxr
posted on 15/10/10 at 10:15 AM Reply With Quote
The engines compression and flywheel play quite a large part in starting.
More compression makes it harder, bigger flywheel makes it easier.
Turbo charged should be easier (as low comp).
Matt
Dopdog
posted on 15/10/10 at 02:58 PM Reply With Quote
Yeah man get it on lets see that car finished
