Author: Subject: HAZARDS
ZUKI
posted on 16/6/04 at 08:32 PM Reply With Quote
HAZARDS
has anyone got a wiring diagram or even explain which goes where one a westfield/demon tweeks type hazard switch.causing me much hair loss.
posted on 16/6/04 at 08:34 PM Reply With Quote
There is a wiring diagram on our website - not specific but it may help!
Click HERE
HTH
[Edited on 16-6-04 by Hellfire]
RoadkillUK
posted on 16/6/04 at 09:53 PM Reply With Quote
I've not done mine yet, will be in the next couple of weeks though. I've been hoping THIS SITE will help me
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 17/6/04 at 09:10 PM Reply With Quote
From that - are you wiring it into a BEC or a CEC. Is it a loom u made yourself or a bought one? Lots of questions...
NS Dev
posted on 18/6/04 at 07:55 AM Reply With Quote
but the principle is the same whatever, you need the switch to connect the supply that comes via the flasher unit, to the left and right indicator circuits, job done. If you get a cheap multimeter and continuity check the switch in the on and off positions you can find out which connections are which, not difficult really.
posted on 19/6/04 at 08:21 AM Reply With Quote
I agree NS Dev however, I had a right nightmare as I chopped out the sierra hazard part, and re-routed through a multi-illuminated switch. Not knowing what contacts were switched when in open or closed positions made me very old overnight... I've now regrown my hair, but not before my hair going completely white then falling out in my quest to solve it. I'm no 'trician by the way, which makes it more of a challenge. However, it was all worth it in the end as the SVA man said "Crikey it even works correctly!" praise indeed. Well I thought so...
I've got the Digi-gear Indicator to sort soon - yet another challenge.
colibriman
posted on 27/6/04 at 10:25 AM Reply With Quote
im in the middle of this turmoil of connecting my mes loom to sierra stalks....without a sierra manual,has been melting my head (and im a sparky),getting somewhere though....got hazards but no indicators yet...
colibriman
posted on 27/6/04 at 02:05 PM Reply With Quote
got indicators now........and sidelights...no dip or main beam yet...
posted on 27/6/04 at 04:59 PM Reply With Quote
Don't forget the brown and black wire that connects between the two switches. It held us up for a while. The dip and main relays earth through the switch on mine.
[Edited on 27/6/04 by Peteff]
