Author: Subject: Foglight wiring for IVA compliance.
stevegough
posted on 20/11/10 at 07:20 PM Reply With Quote
Rear Foglight. The IVA states that the foglight should only be enabled with main beam and dip beam - NOT side or position lights.
I bought my loom from premier wiring two years ago when I started my build - at the time the SVA was in force, and that allowed the fog to be on with position lights as well.
Ok, so after much head scratching, I rang a very helpful Alan and he told me I needed to fit a relay. He described the circuit to me in great detail, and I followed his instructions - took me a while because I had to remove the dash and uncover the control column.
BUT - Success! It worked! Therefore, I have drawn the mini-circuit and do hereby donate such knowledge to you....
One further point - Alan says that the looms he is making now incorporate this mod, so hopefully most of you won't need to go through this......
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
bj928
posted on 20/11/10 at 07:34 PM Reply With Quote
i'm sure 86 or 30 should be an earth, not both perminant feed, it might work but i'm sure thats not right, i think the way your doing it, you could take off 86 and 30 and it would still work, so your not using the relay as a relay, your using the switch as a relay and when switched it make the relay work but in the wrong way, but still makes the feed work. someone may know more than me though
should be like this
[Edited on 20/11/10 by bj928]
austin man
posted on 20/11/10 at 07:37 PM Reply With Quote
Probably depend on the sierra column switch there are 2 different types I believe
stevegough
posted on 20/11/10 at 07:45 PM Reply With Quote
My column switch is the 90BG, which uses switched earth. - The earlier 83BG used switched live. The 'usual denotions' applied to the relay here (which were another spare one left over from the Sierra stip out) don't apply. Alan at premier is the expert, and that is exactly how he told me to wire it. - the proof of the pudding is in the eating - and this works!
Anyway, BJ - thought you were very busy driving truckkies around yanks-ville?
Luego Locost C20XE.
bj928
posted on 20/11/10 at 07:54 PM Reply With Quote
i am busy driving big rigs in America, but day off today, and researching viper engine replacement, viper engine not powerfull enough!!!!
Dusty
posted on 20/11/10 at 10:34 PM Reply With Quote
This came up on Rhocar last year, gave the same solution.
Rhocar linky
bj928
posted on 21/11/10 at 04:45 AM Reply With Quote
take off 86 and or 30 and see if it still works, i think it will which means the relay isn't working as the relay, the switch is acting as the relay. if 86 or 30 is and earth and you have just drawn it wrong then it may be working fine, but the way i see it when you flick the switch it makes the other 2 contact drigger the relay and link 86 and 30 together which just loops the perminent feed round on its self, and that could be vary dangerous and cause a melt down if it somehow finds an earth to use!!!
stevegough
posted on 21/11/10 at 09:24 AM Reply With Quote
I haven't drawn it wrong!
The electro-magnetic coil runs from 86 to 85.
When you switch on the foglight switch, the current flows through the coil, the foglight switch and through the lighting switch ('headlights on') and to earth.
The coil being energised connects the +ve at 30 to 87. This feeds power to the light (and the telltale neon).
It works fine.
Trust Alan at premier wiring. He knows his stuff.
Also - I have just lifted this from the RHOCAR site (courtesy of Dusty):....
"Posted 02 June 2009 - 12:11 PM
If using the later sierra stalks you could add a relay which is earthed through your illuminated fog light switch to connection 56 on either of the stalks. Constant fused supply to terminals 86 and 30 on the relay. 85 connected to your fog light switch and then to 56. 87 on the relay connected to the fog light itself and you could tee off this to a dash telltale if your switch hasn't got one.
This is just one option using a relay. Pic below.
Nigel "
Which is exactly the same.
Regards, Steve
[Edited on 21/11/10 by stevegough]
Luego Locost C20XE.
