ed1max
posted on 2/12/10 at 07:33 PM |
vdo speedo
Can Anyone tell me how to remove AVDO speedo from the dash.Does the bezel screw off or do I need to remove the dash.
As you can guess I am new to this.
Eddie
austin man
posted on 2/12/10 at 08:00 PM |
I think there is a clamp on the back which needs the nuts removing when the clamp is removed the speddo can be withdrawn. You may need to disconect
the wiring first if they are short wires
posted on 2/12/10 at 08:29 PM |
There may be 2 knurled nuts on the back holding a couple of metal securing clips in place, just removed the nuts and clips and slide the speedo out of
the dash
tomgregory2000
posted on 2/12/10 at 08:36 PM |
Or it will have a big plastic ring that you unscrew (mine does)
