mcg
posted on 1/1/11 at 10:34 PM |
Track Day Car Lighting
Hi - I'm building a trackday only F27 (wont be used on the road at all) and wondered what I need to have in the way of lighting? (Front lights,
brake lights, indicators)
Then the question would be, can anyone recomend the cheapest way (and simplest) of achieving the necessary lighting?
Thanks in advance.
Matt
matt_gsxr
posted on 1/1/11 at 11:30 PM |
I would guess brake lights and indicators, but its only a guess.
Paddock Spares will sell you Land Rover ones each at £2.35+Vat. So about £20 in total.
loggyboy
posted on 1/1/11 at 11:33 PM |
Depends on the trackday, some are for road legal cars only, meaning you wouldnt be able to race even with lights if it wasnt road registered. Some
take track/race cars, meaning you wouldnt need them (i doubt you would even need fia rain/fog light as they would probly stop the track if weather was
that bad.
RazMan
posted on 1/1/11 at 11:34 PM |
Is a rain light compulsory on trackday cars?
*edit* you beat me to it
[Edited on 1-1-11 by RazMan]
Raz
JimSpencer
posted on 1/1/11 at 11:39 PM |
Hi
Normally if it's not road legal then it's worded something like 'must be capable of passing scruitineering' so a rain light
would be required.
But 'required' or not a Rain Light is a damn good idea, as is indicators (but with a dash mounted switch, not a stalk) IMHO.
speedyxjs
posted on 2/1/11 at 09:26 AM |
I would say some form of front lighting may be a good idea if there is any possibility you will drive it on a wet track.
GMPMotorsport
posted on 2/1/11 at 10:39 AM |
quote: Originally posted by JimSpencer
Hi
would be required.
Most track days that we are involved with state that for "closed Wheel" cars they must have the usual lighting ie indicators, brake lights
etc. It's a good idea to make sure that the car is able to pass scruitineering then there is no doubt of you be able to take part in the track
day, one thing that has been high on the "not being allowed on track" is noise, always check with the organiser what the noise limits are,
they will be clamping down more this year.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
bitsilly
posted on 2/1/11 at 12:15 PM |
I try and keep an eye out for other cars waiting to pass at Track days. This usually happens when it is wet.
When it is wet and you want to pass other cars (like me) I would have your lights on on the front as it makes it much easier to be seen (I have no
windscreen).
As for following cars, I guess rear lights are not that necessary unless it's dark, but brake lights are a must.
I have had a Morgan keeping up with me along a straight, and he did not realise how late I could brake. I had to take evasive action to stop a crash
(I went straight thru the curve). Now I have a high level brake light too!
Indicators are also useful to tell other cars you are letting them past, and to signal that you are pulling into the pits.
My local track would probably let anything on to the track, but I have seen enough prangs and crap driving to not want to save weight or money by
ditching any of the lights lights.
chris666
posted on 2/1/11 at 04:35 PM |
At Silverston when i did a motorsport vision track day, the only check i remember was a sound check.
I dont think lights are compulsory?
Chris
indykid
posted on 2/1/11 at 04:58 PM |
the book a track bat cats (hire and drive) at elvington had no lights and were an absolute nuisance because of it.
brake lights, head lights and indicators are a must imo. if you do winter track days, often, you'll have to have headlights for later in the day
as the light fades
SeanStone
posted on 2/1/11 at 05:41 PM |
At a lot of tracks it is asked of your to indicate right to let the following car know that you're aware of them and it's safe for them to
overtake. I presume hand signals aren't sufficient or encouraged in that instance so I would go for adding lights!
mcg
posted on 2/1/11 at 11:00 PM |
Okeydokie - thanks for all the replies. I'll go on safe side and bang em all on there!
Cheers again
Matt
bigfoot4616
posted on 3/1/11 at 11:34 AM |
i wouldn't bother with indicators on an open car, never use mine on trackdays as hand signals are much better and you don't forget to stop
signalling.
i would also leave the headlights of, again i've never needed to use mine. if visibility is that bad i'm coming of track
brake lights are a good idea though
