dead 3.5 V8 engine with all ancillarys
as above i have a 3.5 V8 from an old rover P6 its a none runner but comes with all ancillarys
the engine is complete with water pump and all pulleys, drive belts, cooling fan
2X su carbs with manifold air box and fitting pipes
2X cast stock manifolds
dizzy with cap and leads
starter motor
alternator
p,a,s pump with pipes
coil , spark plugs
and any other bit belonging to it i find in my garage
i got the engine to use as a mockup motor but no longer need it
looking for around £50 ono for the lot but because off its size it is collect only
if you are interrested feel free to ring or text me
jim 07941#713285
