Author: Subject: Headlight mounting options ?
Tris
posted on 6/1/11 at 10:01 PM Reply With Quote
Hello All,
Ive just about come to the point where i am fitting the front headlights to my spire, and debating with myself regarding the best way to fit them. For the main's and dipped, i am using some Hella 90mm wide units (the same as these - Lights )
Here's a photo of a completed spire which has exactly the same headlight setup that i would like to mimic.
My problem is to try and decide how i fix these to the inside of the fibreglass nose, while allowing them to remain adjustable from either the exterior or interior. The units came with 3 adjusters and a metal ring but unfortunately with no instructions, and ive been unable to get a picture of how other spire builders have been installed.
Does anyone have a picture or idea regards hows best to install these into a fibreglass nose ?
Tris
[Edited on 6/1/11 by Tris]
blakep82
posted on 6/1/11 at 10:17 PM Reply With Quote
not quite the same car, but the same idea. i'm going to get some square fibreglass/carbon boxes made up, witht he correct hole in the back, and the lights just push in from the back. the box can them be shaped to fit the panel its fitting into using a flap wheel in a grinder. as for how to attach the box to your car, it depends on how the body work works. mine has a nice shelf to sit it on, and bolt it to and stick it in with PU and or bolts
________________________
dhutch
posted on 7/1/11 at 10:40 AM Reply With Quote
Carnt see the image?
