Author: Subject: Strange current drain when ign is off.
r1_pete
posted on 8/1/11 at 04:32 PM Reply With Quote
If I diconnect the battery on the E Type for a few minutes, on connecting it back up I get a spike of current draw about 2 or 3 amps, then a constant drain of .003 Amps.
I have disconnected the alternator, radio, interior lamps, clock is seperate battery, and I still get the problem, its as if a capacitor is charging up every time I connect the battery.
Anyone any ideas what other components could cause this?
[Edited on 8/1/11 by r1_pete]
mookaloid
posted on 8/1/11 at 04:41 PM Reply With Quote
fuel pump?
big-vee-twin
posted on 8/1/11 at 04:46 PM Reply With Quote
ECU or maybe emobilizer if you have one
http://www.triangleltd.com
austin man
posted on 8/1/11 at 04:57 PM Reply With Quote
have you tried removing fuses to isolate the problem ? boot lights are notorious for power drain
big_wasa
Coil ?
ReMan
posted on 8/1/11 at 04:58 PM Reply With Quote
Alarm, dodgy suppressor?
mind you 3mA woukld take a year to discharge the battry
r1_pete
posted on 8/1/11 at 05:04 PM Reply With Quote
Fuel pump is off the ignition, its edis and jolt off the ign switch, I've taken the bulbs out of the interior and boot lights, even disconnected the live feed from ign and lights.
I'm wondering if there is a bit of insulation somewhere worn thin and allowing capacitance effect??
A fuse pull session is next, its a console and partial dash removal job though
Confused but excited.
posted on 8/1/11 at 05:59 PM Reply With Quote
"I'm wondering if there is a bit of insulation somewhere worn thin and allowing capacitance effect?? "
A bit of wire wouldn't give you the capacitance to produce the effect that you are getting: A spike of a couple of amps to start with....suggests a fair capacitance, if that's what it is.
The only way to find out, is as suggested, pull all fuses and test one circuit at a time.
Interesting problem, sorry I cannot be more specific.
Good luck with it and don't forget to share when you find out.
Bluemoon
posted on 8/1/11 at 06:53 PM Reply With Quote
Yep capacitance I guess it's fine. 3ma DC drain is fine..
Dan
ReMan
posted on 8/1/11 at 10:25 PM Reply With Quote
I'd also disagree with capacitance.
The drain ought to be trackable as small as it is
SPYDER
posted on 8/1/11 at 10:38 PM Reply With Quote
Does it have a Smiths clock or similar?
They wind up with a "click" every few minutes.
Could this be the source of the spike?
Geoff
Sorry.Just re-read original post. Clock-seperate battery.
[Edited on 8/1/11 by SPYDER]
Bluemoon
posted on 10/1/11 at 10:09 AM Reply With Quote
The initial spike IS capacitance OR some electronics doing something "odd", i.e there is some inrush current. Of course the 3mA is traceable, but it's Sooo small it's not worth worrying about IMHO. For example our fiesta always sparks on connection, this is due to things like the ECU etc. but the residual current drain is naff all..
If you want to tracing it is a simple matter and a good starting place is removing fuses and measuring the current on circuit at a time.
Dan
RazMan
posted on 10/1/11 at 10:25 AM Reply With Quote
0.003 Amps is a very small current drain and is the sort of thing that a clock or immobilisor would draw - maybe the alternator sensing circuit. If you are really set on finding the source I think the only way you will find it is by pulling fuses, but it is a really insignificant drain and should not affect your battery life.
[Edited on 10-1-11 by RazMan]
Raz
ReMan
posted on 11/1/11 at 06:45 PM Reply With Quote
Dan
I disagreed with capacitance of the wiring theory
But I agree that the phenomena is very like "capacitance OR some electronics doing something"
