omega0684
posted on 11/1/11 at 06:34 PM |
Quick Wiring Question please
Evening all,
A quick wiring question please, what amp wire do i need to run from my battery to my ignition switch? Would 25 amps be ok (this wire would not have
cranking amps running through it)
All the best
Alex
stevebubs
posted on 11/1/11 at 06:47 PM |
What tributary circuits do you have downstream? Add up the amps and you'll have your answer..
omega0684
posted on 11/1/11 at 10:21 PM |
im running a 12v ign supply hub from the ignition switch, this will then feed the switches on the dash.
ECU,
Low Pressure Fuel Pump,
headlights & indicators,
fan,
horn,
rear lights etc
oh and digi dash
omega 24 v6
posted on 11/1/11 at 11:35 PM |
If you are powering them all directly then no it will not be enough.
If you are using them as a mixture of direct loads and/or for switching relays then perhaps it'd be enough.
You really need to work it all out on paper
P=V*I
V=I*R
etc.
ReMan
posted on 11/1/11 at 11:52 PM |
You say feeds the switches, which of these are wired with relays?
As said this needs to be a bit scientific and is actually quite pivotal in the way your car wiring is designed
