Author: Subject: motorbike battery on a car
Garyd
posted on 31/1/11 at 09:42 PM Reply With Quote
Hi all,
Is a motorbike battery capable of running my x/flow westfield, if so does anyone know which size I should go for?
I was thinking of using one because of limited space and also cosmetically I could hide the battery.
Any thoughts or help would be greatly appreciated.
Gary
ReMan
posted on 31/1/11 at 09:50 PM Reply With Quote
Normalish bike basttery?
Running it yes, but starting it no!
Look at one of the high output racing (Odessy) batteries for sma;ller lighter car cranking capacity
Garyd
posted on 31/1/11 at 09:55 PM Reply With Quote
Thanks for the reply, I thought that starting may be the problem. I will look into the odessey ones.
RazMan
posted on 31/1/11 at 10:07 PM Reply With Quote
The Odyssey is definitely your best bet - The PC680 is fitted to some MotoGuzzi bikes but they will easily spin up a V8.
Raz
posted on 1/2/11 at 06:54 AM Reply With Quote
Not sure if this is a good idea on an Xflo.
xflo starting can be a problem because they generally use a lot of static ignition advance because of this this hot starting places a bigger than average load on the starter & battery.
