MikeFellows
posted on 8/2/11 at 09:02 PM |
Flow Sensor/switch
can anyone point me in the direction of a switch that I can add into my coolant system that detects flow. I'm not sure if it would be called a
flow switch, flow sensor or something else entirely.
basically I plan to remove the mechanical pump and replace for an electric one but want something that confirms the electric pump is working.
if it helps my coolant system is in 25mm hose.
MakeEverything
posted on 8/2/11 at 09:10 PM |
You could use a differential pressure switch which powers an indicator lamp?
Kindest Regards,
Richard.
posted on 8/2/11 at 09:23 PM |
Plenty of flow switches in central heating systems which would be happy under pressure and getting toasty warm. Not sure many are in-line mind....
MikeFellows
posted on 8/2/11 at 09:25 PM |
funnily enough im looking at central heating systems, but the best I could hope for is 22mm in plumbing stuff, I dont think anyone uses (or if it even
exists) 25mm
http://www.bes.co.uk/products/142b.asp
one of these fellers at the bottom?
omega 24 v6
posted on 8/2/11 at 09:27 PM |
Mmm sounds like something in a combi boiler might do the trick. they have a flow switch I am sure.
Any heating engineers confirm this???
posted on 8/2/11 at 09:45 PM |
Stick with the reliable mechanical pump. Don't bother with a "Craig David"
big-vee-twin
posted on 9/2/11 at 08:49 AM |
You could monitor current drawn by the pump motor using a ct and a bit of electronics, save putting something in your water system
http://www.triangleltd.com
