Author: Subject: Reverse lights
JC
posted on 2/3/11 at 11:48 AM Reply With Quote
Reverse lights
Hi there,
Just to check if I am reading the IVA manual correctly!
Reverse lights are NOT compulsory
however, if they are fitted they must either only come on when reverse is selected OR be switch operated with a 'tell tale' light.
Is my understanding correct and is there an approved symbol for the 'tell tale'?
Thanks!
JC
blakep82
posted on 2/3/11 at 12:01 PM Reply With Quote
Reversing Lamps
Min 1 Max 2
Mandatory
White
No requirement
1200
250
To the rear
looks pretty conclusive to me... page 206
________________________
Humbug
posted on 2/3/11 at 12:02 PM Reply With Quote
I think for SVA it was optional, for IVA compulsory
[Edited on 02.03.2011 by Humbug]
deezee
posted on 2/3/11 at 12:06 PM Reply With Quote
You have to have a reverse light for the IVA. If its switch operated, then it has to have a tell tale light, but oddly the symbol is not listed under section 33 "identification of controls". Weird?
JC
posted on 2/3/11 at 01:27 PM Reply With Quote
Thanks guys, I'm wrestling with a wiring loom at the moment - removed 5 years ago and all the labels have gone crispy and fallen off! Couldn't find the reverse light switch but on further reading, it is on the gearbox. Somewhere!!!!
Tiger Super Six
posted on 2/3/11 at 02:52 PM Reply With Quote
if its a type 9 gearbox the reverser switch is on the drivers side (as located in the car) where the gear stick goes into the gearbox (you will see it on the side).
Mark
Tiger Avon
loggyboy
posted on 2/3/11 at 03:12 PM Reply With Quote
Its note worthy that its needed for IVA, but not for MoT, so should you wish to wire one temporarily and remove post IVA, you could do.
steve8274
posted on 3/3/11 at 04:34 PM Reply With Quote
hi all
how does the reverse switch wire up?
my loom only has 2 wires but the plug with wires which comes from my switch has 3 wires.
any ideas
thanks
steve
