Author: Subject: Aries Locoblade Ignition Switch Wiring
IainL
posted on 5/3/11 at 05:17 PM Reply With Quote
Hopefully a simple question!
I've just brought an ignition switch which is marked with the letters below;
ST
ACC
BAT
IGN
I have the loom supplied by Aries with wires labelled up as below
BAT
Start
Feed
Which wire connects to which terminal on the Ignition switch?
Iain
flibble
posted on 5/3/11 at 06:26 PM Reply With Quote
I know guesses arn't what you're after but....
My guess would be:
ST - Start
ACC- Any other Accessory that you think needs a switched supply
BAT - BAT
IGN - Feed
posted on 5/3/11 at 07:03 PM Reply With Quote
ST
ACC
BAT
IGN
BAT
Start
Feed
Iain
Bat = Bat
St= Start
Ingition = Feed
Simples
