Author: Subject: Cut-off switch, external pull bracket position.
ken555
posted on 7/3/11 at 08:56 AM Reply With Quote
Can I see some picture of how you rigged up the external pull cable bracket?
I can't seen to find a position for the bracket, that allows a smooth pull.
In each case it requires quite a bit of force to move the switch.
My thinking is the internal cable needs to be at 90degree just as the switch disconnects and springs the last bit, however this means the angle when on is quite sharp.
omega0684
posted on 7/3/11 at 09:00 AM Reply With Quote
why not just put it within reach of your driving position on the dash, that way no cable is needed & you can just switch it of with your hand
ken555
posted on 7/3/11 at 09:27 AM Reply With Quote
I already can, it's just in front of the gear lever.
But I need an external pull cable so a marshal can turn it off from outside.
Connecting this:-
to this :-
[Edited on 7-3-11 by ken555]
