Author: Subject: smiths telemetric speedo
lewis
posted on 11/3/11 at 02:16 PM Reply With Quote
hi all,right i have got my speedo working(loose sensor bracket) but the speedo seems to be over-reading i went for a drive today and it said i have done 91 miles! but could not have done more than 40. how do i adjust it? i have no instructions also will i need to put in a code? ie. http://www.greengauges.com/help/faq20.asp if so how do i do this? i am running 14" 60 profile wheels and the sensors are on the propshaft.cheers.
lewis
posted on 11/3/11 at 02:26 PM Reply With Quote
This is how my gauge is set at the moment
(10 is off)
[Edited on 11/3/11 by lewis]
mcerd1
posted on 11/3/11 at 03:23 PM Reply With Quote
yes you'll need to work out the number of pulses per mile then look up and program in the code thats the closest
there are 2 kinds depending on the age of the gauge:
new gauges
older gauges
we'll need a few other thing to work that out for you
whats the rolling radius of your rear tyres ?
should be listed by the manufacturer - if not wats the width? (14" 60 profile isn't enough on its own)
if its reading off the propshaft - how many teeth/ bolt heads are there (1 complet turns worth)
what ratio is your diff ?
lewis
posted on 11/3/11 at 04:07 PM Reply With Quote
Ok some more info 14/60/185 tires the sensor is picking up it's signal from 2magnets glued to the propshaft
posted on 11/3/11 at 04:50 PM Reply With Quote
You still need to know the diff ratio
lewis
posted on 11/3/11 at 04:57 PM Reply With Quote
Not 100% but was told it's a 3.62
Bigheppy
posted on 11/3/11 at 06:22 PM Reply With Quote
Another way is to drive along the road and see what your indicated speed is and compare it with a sat nav. Adjust the switch or number settings and then repeat the test at the same speed on the sat nav and notice how the adjustment has affected the indicated speed, adjust the settings until the indicated speed reads a few mph over the sat nav indicated speed. Job done. It took a few attempts but its how I set mine
lewis
posted on 11/3/11 at 06:30 PM Reply With Quote
But which switches do I move? I take it some are for big adjustments and some are for small?
posted on 11/3/11 at 06:38 PM Reply With Quote
Have a look at the speedometer fitting instructions for how to work out the settings you need not the calibration page
snapper
posted on 11/3/11 at 07:42 PM Reply With Quote
Google Caerbont and look for the instructions, it's all on there.
I eat to survive
I drink to forget
mcerd1
posted on 11/3/11 at 08:11 PM Reply With Quote
its a binary number you programing in - its related to the number of pulses per mile but not the same as it so don't worry too much about what it means
follow the instructions on this page: link
then look up the setting you need here: link
by my rough working
185/60 R14 = ~1762mm per rev = 0.00109485604 miles per rev
so thats 1 / 0.00109485604 = 913.3620891382213 revs pre mile
if your diff is a 3.62 then that means it turns 3.62 times for evey turn of the wheels
and you have 2 magnets so that twice again
so 913.3620891382213 * 3.62 * 2 = 6612.7
so thats approx. setting 6613 = 0100000010
(were 0 is off and 1 is on, starting at #1 ending at #10)
a 3.92 diff would maek it more like 7166 = 1110100010
if I'm reading it right it looks like its currently set on: 6950 = 1111000010
please don't take that at face value - always best to triple check these things before you get done by a speed scamera
{ps - Have I done that right ?}
[Edited on 11/3/2011 by mcerd1]
lewis
posted on 11/3/11 at 08:24 PM Reply With Quote
Thanks alot all especially mcerd1 I'll give the code you have worked out a go,I'll run with satnav to compare so will trust that for now for the cameras!
