Author: Subject: electrics prob on zx14 ???
INDY BIRD
posted on 13/3/11 at 07:28 PM Reply With Quote
Hi all
got a small problem arisen from my last track day,
i keep blowing a 10 amp fuse,
i never wired the car so only can go by diagrams,
its no 3 fuse which accoring to the manual is for the rear stop lights and indicators, it also does the push start button for starting the car,
problem is once i start the car and turn it off again the fuse has blown so wont start, also i then have no indicators or brake lights,??
i started the car this afternoon and tried it a couple of times and it did re start when the engine was cold, but after about 5 mins on idle when car was warm it wouldnt re start and blew the fuse?
any ideas welcome before i dive into the electrics.
i could try a bigger rated fuse but dont want to run the risk of the wire melting if it is for that reason etc,
cheers all for your help
ps this didnt do this before so could be bad earth ???? but not sure
