daniel mason
posted on 15/3/11 at 09:38 PM |
where to buy oils and fluids?
as well as the cleaning and polishing stuff i need for the car i also need all fluids for the f20c install!
where is the best place to buy them from and which would be a good choice? cheers
engine oil (around 5 litres) 10w30
diff oil (0.77 litres) hypoid gear oil gl5 or gl6
transmission oil (1.6 litres) mtf
engine coolant (not sure how much i need exactly)
brake fluid (again not sure how much or best type to use)
MkII
posted on 15/3/11 at 09:43 PM |
EK motor factors caton road lancaster or shap road ind est kendal. .m.
g60_edge
posted on 15/3/11 at 09:55 PM |
http://www.opieoils.co.uk/
posted on 15/3/11 at 10:39 PM |
Coolant use a long life OAT or HOAT coolant Vauxhall dealers have good deals on this they also do good deals on 5w/30 fully synthetic engine
oil.
Oil check the exact oil spec for your engine ---- 10w/30 isn't a grade that is in very common use 5w/30 or 10w/40 are more usual.
Generally where 10w/30 oil semi-synthetic is listed a 5w/30 fully synthetic is suitable but choosing the correct oil grade is getting much more
complex by the day for example some Japanese motorcycle engines require an obsolete API SF or SG spec mineral oil not more modern API
SN,SM, SL and SJ spec oils which have less anti-wear additives.
[Edited on 15/3/11 by britishtrident]
mrwibble
posted on 15/3/11 at 10:43 PM |
trick with opie is to add something to cart then leave the website, you have to be signed in, they emailed me earlier to say sorry u didn't
finish ur purchase was it the shipping costs? use promo code "shipsnip" to save £3.00 on postage...
daviep
posted on 16/3/11 at 12:08 AM |
nice tip, thanks
