nib1980
posted on 16/3/11 at 03:26 PM |
4age Starter wiring
HI All
I was wondering if anyone can tell me where the extra wire goes to from the 4age starter?
I previouly had a xflow, so have connected the big wire from the starter solenoid to the starter, but now just a little confused where the little wire
goes?
many thanks
Neil
JeffJeffers
posted on 16/3/11 at 05:04 PM |
Is it for the warning light on the dash?
cs3tcr
posted on 16/3/11 at 07:23 PM |
Are you running a remote solenoid? Ie you're running a solenoid, then the starter? If so, you would have to connect the small wire to the
main terminal on the starter.
The toyota starter has an integral solenoid, so to keep it simple, the large terminal would be your battery power, the small terminal (typically has a
black plastic surround) is the lead from either your starter switch or the "start" position on your iginition switch.
[Edited on 16/3/11 by cs3tcr]
nib1980
posted on 16/3/11 at 08:42 PM |
the xflow had a remote solonoid and by the sounds of it the toyota doesn't.
i think i understand but could you do a little diagram for me?
many thanks
Neil
cs3tcr
posted on 16/3/11 at 08:58 PM |
Here's a rough sketch:
nib1980
posted on 17/3/11 at 08:17 AM |
thats perfect and makes sense now.
many thanks
Neil
