lotusmadandy
posted on 19/3/11 at 08:00 PM |
Ecu location
In payment for modding the sump on a blacktop and making the idler/engine mounts,
i have been given a 2.0 blacktop from a mondeo with the ecu,loom,keys,etc.
Can anyone point me to the location of the ecu under the dash,to save digging around in the wrong place.
Is there anything else that i need to make sure that i take from the donor before it gets scrapped?
[Edited on 19/3/11 by lotusmadandy]
big_wasa
posted on 19/3/11 at 08:13 PM |
On a mondeo its just above your toes
Lift Bonnet and pull power steering res to one side.
Drill two rivetts out of the anti tamper steel cage.
Undo 10mm bold that holds plug to ecu.
Two 10mm bolts on mounding plate.
One 10mm bolt on the bottom bracket from under the dash.
Pull out
You want the aerial from around the ignition switch Its differant to a silver top and its plug. Whilst there you want the obd2 plug and as much cable
as you can free.
Back to the engine bay.
One 10mm bolt seperates the engine from the car loom on the Ns inner wing. And the loom goes around the back of the engine.
He wont need Maf or Lambda sensors so grab them aswell.
Simples, then comes the wrring
[Edited on 19/3/11 by big_wasa]
lotusmadandy
posted on 19/3/11 at 08:28 PM |
Cheers for that Warren,i did plan to take the complete loom out to be sure i had it all
But that will be easier to get out
big_wasa
posted on 19/3/11 at 09:08 PM |
The whole loom is handy if your going to trace it all back but you only really need the engine loom.
lotusmadandy
posted on 19/3/11 at 09:31 PM |
Ok,
So all i need from inside is the car is the aerial with wiring and
the obd2 plug. where is the obd2 plug?
Is that the diagnostics plug?
RichardK
posted on 19/3/11 at 10:46 PM |
Andy, is it an auto, believe the ecu is very different and not much use to us...
Rich
Gallery updated 11/01/2011
lotusmadandy
posted on 20/3/11 at 07:45 AM |
Thanks for the information chaps,i will get what is needed
from the donor.
Rich it is a manual mate,so no worries
big_wasa
posted on 20/3/11 at 10:21 AM |
As Rich says an auto is bugger all use I just assumed its a manual.
Yep diag' plug is in the trim panel above your feet. Its meant to be in reach of the drivers seat in all cars.
Does this mean yo have seen the light of OEM injection
lotusmadandy
posted on 20/3/11 at 10:58 AM |
"Does this mean you have seen the light of oem injection"
I might have Wasa
