KECHICHE
posted on 29/3/11 at 09:56 AM |
mt75 to what zetec engine?
Hi guys what engine will be best to use with the mt75 gear box and do i have to do any mods? Cheers Alex
big_wasa
posted on 29/3/11 at 10:41 AM |
Any zetec E ( not SE )
So thats the 1.6, 1.8, 2.0 as fited to the Mondeo, Focus, Escort, Orion, OLD Fiesta's as well as others.
Mods depend on engine ie You may want to shorten the sump and metal will be needed to be hacked of for starter motor clearance, more so on a black
top.
You shouldnt need to touch the block or head.
The easiest engine to fit would be a pre aug 1995 silver top from an escort/fiesta.
Induction/ exhaust and ancileries is another thread
As per your u2u There is no reason why a dohc wont fit but I wouldnt fit one my self.
KECHICHE
posted on 29/3/11 at 02:02 PM |
Ok cheers for that,the dohc did fit and bolted onto the chassis but its too big for the bonnet and the injection unit higher than the block so ive got
more work to do in the next process.thanks
KECHICHE
posted on 1/4/11 at 04:12 PM |
Hi there pls advise does it mater if the engine was a transvers engine and will it fit north south.
(i found asomeone to swap with my dohc engine for a 1600 silver top escort mk7 engine) will this suit the mt75 gear box? thanks Alex
big_wasa
posted on 1/4/11 at 04:27 PM |
yeh if the 1600 is a zetec E and not an S(E) ie iron block then it will fit fine. Beaware the 1600 has smaller ports ect and is only around 90bhp as
standard.
I dont think the se was ever fitted to the escort but could be wrong.
1.8 would be much better but if its free it will be easier to swap a zetec for a bigger zetec at a latter date. And the silver top escort is an easy
fit and some even use the sump unmodified
I can not think of any zetec e that was ever anything but transverse even in 4x4 format.
