Author: Subject: Start Button
Greenie
posted on 2/4/11 at 07:47 PM Reply With Quote
Start Button
Fitting a Savage push start button, do I need a relay and if so which is the best to get?
snowy2
posted on 2/4/11 at 08:46 PM Reply With Quote
you don't need a relay to start a car just run a ignition live to one side of the switch (a flick switch like you would use for washers) and the other to the starter solenoid. i have in the past used a hidden micro switch to start a car...
RazMan
posted on 2/4/11 at 10:52 PM Reply With Quote
I forget the current rating of the switch but I made sure it wouldn't have any trouble with the load of the solenoid by connecting both sides of the microswitch in parallel. It has worked for 5 years like this with no problems.
Raz
