Author: Subject: slim Hella brake light
jabbahutt
posted on 4/4/11 at 03:00 PM Reply With Quote
Afternoon all
I believe that Hella do a high level brake light the is onlt 9mm thick and would be ideal for mounting to a rollbar. I'm stumped though to find anyone who stocks it or find any other info on dimensions etc.
Anyone here come across it?
Nigel
omega 24 v6
posted on 4/4/11 at 03:23 PM Reply With Quote
Use em at work i'll get a part no for you.
Ok the ones we use are 24 volt.
there are 12v ones like this but you may also need a connection kit/harness. the ones we use have a 3mtr length of cable not sure about the 12v onesd though as the castalogue lists a connection harness.
Description and part no is
Auxiliary Stop Light LED red, 12 V
Part no.: 2DA 007 858-037
[Edited on 4/4/11 by omega 24 v6]
it can be found here then go to lighting/lights/stop lamps.
Hella site
blakep82
posted on 4/4/11 at 04:25 PM Reply With Quote
that hella website is the most infuriating, hopeless catalogue i've ever tried to use.
i've spent hours trying to find the plugs i need for the hella headlights i bough, and can't find them.
________________________
omega 24 v6
posted on 4/4/11 at 04:35 PM Reply With Quote
Usually they are listed under the head lights as " accesories" stick up your lights blake and i'll see if i can help. And yes your right the site is APITA
jabbahutt
posted on 5/4/11 at 06:21 AM Reply With Quote
many thanks for all your help
