Author: Subject: Which resistor for legal flash rate ??
tompat3463
posted on 10/4/11 at 05:07 PM Reply With Quote
Hi guys.
I fitted myself some little Arrow indicators to the front of my Indy..
However the flash rate is round double the legal rate..
There fitted with 23w bulbs
Just wondering which resistor I need and how the hell I go about fixing them ???
TIA Alan
Jon Ison
posted on 10/4/11 at 05:17 PM Reply With Quote
Search ebay for a LED flasher unit, easier and better fix than a resistor
Jon Ison
posted on 10/4/11 at 05:20 PM Reply With Quote
LED Flasher Unit 12v - up to 30w - 4 Pin | eBay UK
tompat3463
posted on 10/4/11 at 05:23 PM Reply With Quote
ok thanks...
How do I go about fitting that then mate ???
Jon Ison
posted on 10/4/11 at 05:25 PM Reply With Quote
Direct replacement of your current flasher unit, only down side if a bulb goes you wont know as it will always flash at the correct rate.
Is yours a 3 pin or 4 pin unit, I linked to a 4 pin.
tompat3463
posted on 10/4/11 at 06:20 PM Reply With Quote
ah I seeee... ok will get that ordered..
Very helpfull... thanks Alot mate
brookie
posted on 10/4/11 at 06:28 PM Reply With Quote
u prob need the 3 pin one m8 im going have to get myself one as well
[Edited on 10/4/11 by brookie]
PeterV
posted on 11/4/11 at 10:46 PM Reply With Quote
6.8 ohm 25W mounted to the chassis for cooling works perfectly. Less than £1.50 each in most places.
