Author: Subject: Any Ideas
j3w3ll3r
posted on 11/4/11 at 06:36 PM Reply With Quote
Any Ideas
Hi
Just found this wire under the car, its not connected to anything
Could it be from timing equipment, if not anyone got any ideas
Stephen
www.essexhomegame.co.uk
j3w3ll3r
posted on 11/4/11 at 06:37 PM Reply With Quote
Oooooh thats a bit big, maybe i should shrink it a bit
posted on 11/4/11 at 06:40 PM Reply With Quote
Yes - it is a bit OTT!
And that looks like the connector for the reverse switch on a ford type 9 gearbox.
blakep82
was it a reverse light switch off a type 9 box (and maybe some others) ?
________________________
CRAIGR
Contributor
Posts 2762
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
Looks like a mahoosive reverse light switch connector from the g/box.
stevegough
posted on 11/4/11 at 06:43 PM Reply With Quote
Reverse light switch connector, but I've never seen one wired up with armoured cable before
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Richard Quinn
posted on 11/4/11 at 06:44 PM Reply With Quote
No way!! It's far too big to fit!
beagley
posted on 11/4/11 at 06:58 PM Reply With Quote
You definitely can't say there isn't enough detail in the picture
I'm not scared!!! I'm just marking my territory.
omega 24 v6
posted on 11/4/11 at 10:04 PM Reply With Quote
Reverse light switch plug. I can just see the switch itself on one of your photo's.
