marcjagman
posted on 16/4/11 at 04:47 PM |
Will a digital dash from a GTE work?
I'm sure someone here has fitted a digital dash from an old Astra GTE to their car, how easy/hard is it to fit and get working properly? Is
there a loom available to make it all work or is that hoping for too much? Anyone on here know how it's done?
karlak
posted on 16/4/11 at 04:53 PM |
here ya go -
http://www.locostbuilders.co.uk/viewthread.php?tid=53512
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
daniel mason
posted on 16/4/11 at 05:32 PM |
its not as easy as plugging in a loom. what ecu are you running? and does the tacho read upto 13.000 rpm? i was having a similar problem with the
honda s2000 clocks. they need a lot of work to work correctly. as does the indicator/lighting controls. they need feeding through relays to stop them
burning the switches out
brookie
posted on 16/4/11 at 05:58 PM |
hi m8 where about in pontefract are u could go out for a blast some time
Ben_Copeland
posted on 16/4/11 at 06:35 PM |
Unless you have a bike engine that only revs to 7k and a vauxhall gearbox with gearbox transducer, i'd say dont bother.....
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
loggyboy
posted on 16/4/11 at 08:35 PM |
Very simple dials from a simple era, no fancy multiplex or canbus to worry about.
Buy a pulse converter (picbits.co.uk) and you can convert any speed impulse and callibrate it to suit. You could even use a 2nd pulse converter to
convert the rev signal to suit any rev range and tweek the dial face numbers.
The above site also sell colour conversion kits for the gte dashes to brighten up the dull 80s yellow glow. (used to sell them anyway)
The guy who runs that site is called Dom and he frequents Migweb.co.uk.
