Author: Subject: indicators flash speed with engine on
locostbuyer83
posted on 19/4/11 at 05:54 PM Reply With Quote
Just noticed that my indicators flash faster the more the engine revs. please could someone let me know how to fix it?
im sure im not the first one with this problem
westf27
posted on 19/4/11 at 06:01 PM Reply With Quote
sounds like a regulator problem causing too much voltage.Meter test the voltage across the battery at idle and high speed.I assume that your flasher unit is loaded correctly with the right wattage bulbs.Alternatively slow down or dont indicate at high speed
555
posted on 19/4/11 at 06:03 PM Reply With Quote
Before doing anything to the flasher system I would put a voltmeter across the battery and check the battery/charging voltage at various RPM conditions.
westf27
posted on 19/4/11 at 06:07 PM Reply With Quote
evening,its been hot down here,what about where you are
555
locostbuyer83
posted on 19/4/11 at 06:20 PM Reply With Quote
put my meter on the battery and its consistent, doesnt go up and down much when increasing engine speed.
