Author: Subject: where to buy diodes asap
daniel mason
posted on 20/4/11 at 12:47 PM Reply With Quote
i need a few diodes for my hazard for my hazard light circuit to stop the tell tale lights from being constantly on
r1_pete
posted on 20/4/11 at 12:53 PM Reply With Quote
50 1N4004 400V 1A Silicon Bridge Rectifier Diodes RoHS | eBay UK is one supplier, unless you have a local electronics hobbyist shop you can go and buy over the counter
sickbag
posted on 20/4/11 at 12:57 PM Reply With Quote
You should be able to get one from your local Maplin store.
Finally back on the job!
Miks15
posted on 20/4/11 at 01:17 PM Reply With Quote
if you do buy a big pack could you pop a few in the post for my set up? Doing the same thing as you and havent got round to doing the diodes yet. Can send a bit for postage if you want.
daniel mason
posted on 20/4/11 at 02:12 PM Reply With Quote
course i will mate, if you want any advice on the wiring of the hazard switch i can probably help. i just need the diodes to stop the light bieng on permanent.
i was also thinking of putting diodes on the switched live for the side lights,as well as headlights to feed the fog light from as the fog must only work when other lights are on.
Miks15
posted on 20/4/11 at 02:58 PM Reply With Quote
What loom are you using?
Is it one youve built from scratch?
daniel mason
posted on 20/4/11 at 03:34 PM Reply With Quote
yeah i have the cbs wiring module but the loom is mine.
