blakep82
| posted on 20/4/11 at 06:18 PM |
where am i likely to find something like this?
my new denso pulley has a 15mm hole, and the pulley has a 17mm hole
the easiest fix i can see is to put this sort of thing in
its tiny though, too small to be done on a lathe i think... any ideas?
________________________
hucky
| posted on 20/4/11 at 06:23 PM |
may be a long shot buy try a cycle shop, see if they have any head stem spacers. they may do the job if small enough. carbon, steel and ali i think
they do them in.
blakep82
| posted on 20/4/11 at 06:28 PM |
awesome halfords? or do i need to be more specialised than them?
i think theres a specialist round here somewhere
hucky
| posted on 20/4/11 at 06:40 PM |
just been looking for them on the net, didnt look at the size, these are going to be about 20mm+ at least not 1.5. but what about maybe a sump washer?
their are some small nissan ones about, or maybe fibre washers depending on its use?
mcerd1
make one on a lathe - it can be done
[edit]
thinking about it a bit more - is the pulley a press fit job ?
[Edited on 20/4/2011 by mcerd1]
blakep82
| posted on 20/4/11 at 07:00 PM |
[edit]
press fit, no, its tight, but came off its original alternator by hand
mcerd1
| posted on 20/4/11 at 07:02 PM |
^^ I think I've sent you too many u2u's now :?
have you got a pic ?
oadamo
| posted on 20/4/11 at 07:03 PM |
cant you open the hole up in the pulley to make the spacer ring bigger.
adam
hucky
| posted on 20/4/11 at 07:10 PM |
what altonator is it off?
oadamo
| posted on 20/4/11 at 07:11 PM |
or if its a steel pulley just weld the hole up and lathe it out again.
adam
blakep82
| posted on 20/4/11 at 07:16 PM |
adam
ooh, i like it. think this may work out well! i'm going to take to someone tomorrow, see what he says before i weld it up!
oadamo
| posted on 20/4/11 at 07:18 PM |
adam
ive done it before i welded a ring in the middle of the hole to build it up then filled it each side. just dont go mad let it cool a few times.
adam
saying that you only need a mm i would just put a thin weld around it then skim it out.
adam
[Edited on 20/4/11 by oadamo]
