Author: Subject: Flasher relay
chrisxr2
posted on 22/4/11 at 07:41 PM Reply With Quote
Flasher relay
no indicators at all, checked wiring, guessing relay has died.
wehrle
13 010 301
12v
pa6 6gf15
10r- 027024
googled it and not a sausage, anyone any tip or will any 12v 3 pin flasher relay do??
Life moves pretty fast, if you don't stop and look around once in a while, you could miss it.
spiderman01980
posted on 22/4/11 at 08:06 PM Reply With Quote
there should other numbers on there i.e 23wx2+3.4w, they are all different.
try this site http://www.aopec.com/new/en/products/?class_id=17
[Edited on 22-4-11 by spiderman01980]
snowy2
posted on 23/4/11 at 03:52 AM Reply With Quote
if yours is a 3 pin relay then it is almost certain another 3 pin relay will work, (if you are using LED bulbs you may have problems) but if your using standard bulbs you'll be fine
Check the hazard switch as non working indicators can be often be traced to the switch not being fully in one position or the other!
[Edited on 23/4/11 by snowy2]
sometimes you are the pigeon, most of the time the statue.
posted on 23/4/11 at 07:08 AM Reply With Quote
If you are using Sierra column switches and have been caught in the rain the switches may well have got wet , try a squirt of contact cleaner around the hazard light section ,WD40 might work.
Michael
posted on 23/4/11 at 08:01 PM Reply With Quote
My indicators do not work if the Hazard switch is disconnected
(Mine is a seperate switch on the dash & indicators are on the stalk on column)
chrisxr2
posted on 23/4/11 at 08:31 PM Reply With Quote
thanks all
Thanks all, i believe i need an led one as my fron indicators are led, just stopped working, no water or anything anywhere near, tried putting hazards off and on few times but no dice.
